no signal
Go to solution Solved by Letgomyleghoe,
3 minutes ago, iamlegs said:
ok it works now thanks but why did it work before in my other board?
Your other board probably had a cpu with integrated graphics, do you know the cpu on your other board?
Do you have another monitor or cable to test.
So we can see if its the monitor or the pc.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311591
Just now, iamlegs said:
what do you mean by that?
Where you select which port your monitor should use. There is usually a button that says menu and then switch to HDMI or DP whichever you have connected.
Make sure to quote me @Meowster  so that I see your reply
I love my job, being a sysadmin. It's very fun
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311628
oh yea i try all of them non work
I would suggest by re-seating all of the RAM modules. I had this problem on my Home Theatre PC and it seemed to fix it. Let me know if you have any luck
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311641
1 minute ago, iamlegs said:
do i rly i only had this pc for 2weeks
Ohh sorry didnt realise. Could you give me some specs of your rig and then maybe we could try some solutions?
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311649
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311660
So, lets start from the beginning:
Your PC does not output any video signal
1.Did you build this PC yourself?
2.If your motherboard has intergrated graphics output, you should try that
3.I would check all cables inside the PC (especially the GPU)
4. When the PC stopped working, did you hear a sound like when you unplug a USB drive?
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311670
my pc is turnign on
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311672
my pc was never not working
I thought you said in the very beginning that it was showing no signal. Maybe I just misunderstood. Sorry about that
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311684
2 minutes ago, iamlegs said:
so do you know hwo to fix it?
Is your PC connected via HDMI, DP or something else?
Edit: In the worst case, there could be a problem with the monitor
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311714
His cpu doesn’t have integrated graphics.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311716
what do you mean?
Some CPUs have a graphics card integrated with the cpu, for some reason @Meowster thought that yours had integrated graphics, when in fact it did not.
now on the obverse side, if your cable to your monitor is plugged into your mobo, it should be plugged into your gpu.
AMD blackout rig
https://linustechtips.com/topic/1157516-no-signal/#findComment-13311728
