Oh pins is trouble! I hope it isn't pins.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123051
Apart from being messy, the thermal paste shouldn't be conductive anyway so it in theory shouldn't hurt anything.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123075
I meant trouble getting it out. Not trouble as in functional damage.
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123091
Ahh makes sense:)
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123099
http://www.arcticsilver.com/arcticlean.htm
That and a microfibre cloth :-)
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123239
Ok I tried cleaning it but the pads are a little darker where the paste was. So is it not fully cleaned?
Had the same problem, my pads are little darker aswell, doesnt seem to affect anything cause its still working for me.
Also in respond to firefox: It shouldnt be conductive and it isnt with the arctic silver 5, But read this:
Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
So still watch out with it :)
Running: i7 4770k cooled by Swiftech H220 (Delided and Lapped) (5ghz+ capable) - MSI Z87 mPower MaX - 4x 4gb 2400mhz corsair vengeance cl10 - 660Ti Graphics in a Fractal R4
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-123254
Not Electrically Conductive:Arctic Silver 5 was formulated to conduct heat, not electricity.(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
Ok what did you use to wipe off the compound Located?
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-124069
I used a piece of toiletpaper but i suggest you use lint free cloth
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-125308
Ok what are the exact steps you followed? Sorry I'm just nervous
Take the a lint free cloth, and then wipe the bottom of the CPU. There's not much that can go wrong. Use a little alcohol on the cloth and wipe the spot afterward, to make sure its very clean.
https://linustechtips.com/topic/11555-cleaning-cpu-pins/#findComment-127045
