Cheap isn't a fixed amount. We need numbers and more detail (i.e. what all do you need?)
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256429
there is a subforum dedicated to discussing new builds where you can get multiple inputs, rather than dms
and usually a budget is helpful if you get there
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256431
Can't tell if they're begging for money or if they actually need help with choosing parts.
OP, you need to elaborate a bit more.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256438
21 minutes ago, SKEJ said:
I can do up to 100$
That's plenty for you first computer, get your hands on an older desktop from the likes of dell and such, It'll be great for CSGO, Minecraft and less demanding games like that. You will always have an opportunity to grow with the desktop and grow with it over the years, good luck!
Edit
Now with that said, for someone not too familiar with what classifies as a good buy, would suggest getting your priories straight and ask yourself what you are looking to play, with your budget in mind and the kind of system you are looking for and the bargain level PCs in particular being of interest. Share some post from the marketplace here and ask members if they think it's a good buy compared to x y z, it'll go a long way, next thing you know you'll be shopping for a new GPU 6 months down the road looking for more performance ?
Again good luck and happy birthday! Wish you the best~
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256460
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256470
27 minutes ago, SKEJ said:
Thank you very much can I get a guide to how to put it together to I am not the most experienced person.
The move for a basic machine in that range at least used to be to buy some sort of old prebuilt office desktop that was NOT a SFF system, but had 4 cores.  Ideally 4/8, 8meg of memory, preferably more, and the. Put a 1650ti or a 570 or some other card that did not have an external power port, and then you could play whatever it had. Which was 1080p or less.
I don’t know how well that recipie holds up any more.
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13256521
Try your area via Facebook Market, Craigslist, LetGo, etc.
I frequently pick up used gaming rigs for around $100-150.
For example, here are a few I've attained:
https://pcpartpicker.com/user/trevb0t/saved/#view=dzvTBm
https://pcpartpicker.com/user/trevb0t/saved/#view=nbJVcf
https://pcpartpicker.com/user/trevb0t/saved/#view=FLWZZL
There may or may not be anything immediately available, but if you watch the market, you'll find it!
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257150
https://sg.pcpartpicker.com/user/trevb0t/saved/#view=nbJVcf
https://sg.pcpartpicker.com/user/trevb0t/saved/#view=dzvTBm
https://sg.pcpartpicker.com/user/trevb0t/saved/#view=FLWZZL
singaporean lists?
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257155
7 hours ago, SKEJ said:
Ok??? Um I will try????
The reason for no SFF systems is they frequently had either no pcie slot for the video card or no space in the case to put a card.
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257157
you just put the card in and there's that. search google on how to open the side panel.
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257161
Clearly you've never seen this oddly sensual tutorial:
Heh optiplex i7 for $120.  Iirc they’re more like $300-400 now
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257175
You're missing the conversation prior to all of this.
I'm not suggesting OP will find this gear.
I'm pointing out a funny guide to how to put a GPU into an Optiplex, since HM stated none was needed.
But you're right. An i7 for $120 is an unreasonable ask these days.
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257186
you can find a few sandy bridge i7 prebuilts for $130-150 on ebay, but then the PSU usually doesn't have enough wattage anyway. Another way is to find a LGA 1366 workstation and upgrade to a 6-core xeon. the xeons cost peanuts now and they're more likely to have PSUs that have enough wattage.
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257206
I got a 4770k with a weak OC on it, making it more powerful than that optiplex, and I’m not counting on the thing to live past April.  I saw some SFF i5s on eBay that might maybe be modable. 4/4 is even less likely to cut it than 4/8 though
https://linustechtips.com/topic/1150381-pc-build-help-sub-125/#findComment-13257207
