Easiest way to switch to single monitor from dual to maintain FPS?
Robin_Code
Hi,
So I build my new rig and wanted to be sure about not having gaming issues. I also do programming ed and I feel I need a second monitor for productivity.
Question. To make sure FPS doesn't drop while gaming, do I always need to ⊞ Win + P / Single monitor or do I need to unplug my DP cable every time? The reason why I am asking is because if I need to remove my cable everytime, I'm not going to buy a second one at all.
17 minutes ago, Robin_Code said:
Hi,
No, a second monitor won't affect your FPS, if you stare at the desktop and look at your GPU usage you'd see that it's using 0%.
Quote or Tag people so they know that you've replied.
AFAIK it will decrease performance but only like 0.5% less fps or something neglectable.
Just keep them both plugged in and running, you'll be fine.
If you only game/render on one of the displays though you could connect it to your iGPU and therefore completely separate the two displays.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
That's true it will, I just didn't want to mention it since it's even less than 0.5%, it would be very difficult to measure, assuming it's just a normal desktop with nothing taking advantage of your GPU.
