Logitech G HUB is bugged
Hey, I'm glad you posted on the LTT forum! Logitech G Hub is quite the piece of work and very buggy. Logitech has poor software development and quality control on their products ranging from the popular wireless Logitech M325 mouse to their Gaming line of products and unfortunately, I don't see that changing any time soon as they don't even provide a proper support to express your concern. As for your G Hub issues, find the download location, in my case "C:\Program Files\" . Once there delete the folder named "LGHUB" and all its contents. If any issues arise, make sure the application isn't open in your task manager or your system tray. Upon deleting the folder and checking that the application is not longer running, head on over to Logitech G Hub's download page and download the latest version for your system, (this is exclusively a 64 bit application), should properly install without error, granted you followed the instructions from the installer.
Let me know how that works, E.J.
