1 minute ago, Samin said:
My cpu is Pentium dual core e5400 @2.70 ghz.my ram is 6 gb ddr3 and i have a gpu which is Sapphire amd Radeon r7 250 1gb gddr5 which i bought recently.But the problem is i get so much frame drops in games like "cod mw2".how can I fix this???
Thanks for posting 2 of the exact same post.
your running a pentium with a gddr5 GPU. probably a bottleneck assuming that gpu is much newer then the pentium.
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
Dual core CPU, 6 gigs of RAM.. Thats extremely underpowered even in 2015 terms.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
This is just a guess, but I would wager that the culprit is probably your aging e5400 having difficulty both running the game and handling windows background processes.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Ohhh
yeah, basic stuff.
a 2007 CPU with a 2013 GPU, isnt going to mix. PLUS, both of those are shit by todays standards anyways. so you wouldnt get good FPS regardless
Not to mention that it is a Wolfdale processor.
1 minute ago, LamoidZombieDog said:
yeah, basic stuff.
Well the game is from 2009 and the CPU is actually from 2009 as well, even still though.
That CPU will bottleneck pretty much EVERYTHING you try to play. It has only 2 cores with 2 threads and only clocks at 2.7 Ghz. Your GPU is also not suitable for ANY modern games since 2013 or so.
You need a completely new system if you intend to play games.
ESL Profile: https://play.eslgaming.com/player/2432327/
F@H Profile: https://folding.extremeoverclocking.com/user_summary.php?s=&u=847206
Old System:        Current System :
i7-3770k + Cooler Master Hyper 212                           i9 9900k + Noctua NH-D15
Gigabyte Z77M-D3H                                                    Gigabyte Aorus Z390 Master
Evga Geforce GTX 970 SC                                          GIGABYTE GeForce RTX 2070 SUPER GAMING OC (F@H OC +70core/+580 mem)
HyperX FURY Red 16GB  DDR3 1600                        Corsair Vengeance  LPX 2x16GB DDR4 3200
bequiet PURE POWER 600W 80+ bronze                  Corsair RM 650x 80+ gold
Samsung 850 Evo 120 GB + 1TB HDD                       Samsung 970 Evo Plus 500GB
        Thermaltake Level 20 MT ARGB
What motherboard do you have?
You can probably throw that little dual core out and replace it with a Q6600 quad core. These things are dirt cheap (literally $15) and will dramatically increase your performance.
After that IMHO you could even get a nicer GPU.
Edit: but then again, please don't expect any miracles to happen with a new CPU. That GPU is still very very weak and you'll not get anything better than 720p low and everything turned off out of it.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
44 minutes ago, LamoidZombieDog said:
your running a pentium with a gddr5 GPU. probably a bottleneck assuming that gpu is much newer then the pentium. a 2007 CPU with a 2013 GPU, isnt going to mix.
Is this the reason why people ask if they need DDR5 motherboard for GDDR5 gpus?
HD5850 from 2009 has GDDR5 and it's stronger compared to OPs gpu from 2013, E5400 is from 2009.
yeah, basic stuff.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
You need to upgrade the CPU.
and your GPU.
you'll also probably need to upgrade your PSU for both of those.
