Best Motherboard under $150 for 3600 Overclocked?
I'm looking for a good motherboard around $150 to use for a Ryzen 5 3600 Overclocked. Heres my current planned specs. Parts marked $0 will be taken out of my old prebuilt until I can upgrade them.
PCPartPicker Part List: https://pcpartpicker.com/list/4cGTPn
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($189.99 @ Amazon)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Memory: Crucial Ballistix Sport AT 8 GB (1 x 8 GB) DDR4-2666 Memory  ($0.00)
Storage: Samsung PM961 128 GB M.2-2280 NVME Solid State Drive  ($0.00)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($0.00)
Storage: Seagate FireCuda 2 TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($0.00)
Video Card: Gigabyte Radeon RX 580 4 GB Gaming 4G Video Card  (Purchased For $0.00)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($98.99 @ Walmart)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Newegg)
Total: $388.96
Generated by PCPartPicker 2020-01-21 20:07 EST-0500
Can anyone recommend a good motherboard for this CPU at the around $150 price? Thanks!
Did you try all possible video outs on both cards. Sometimes windows will be picky about outputs on new builds until all the drivers get hammered out in updates. I’m assuming you have installed the latest Nvidea drivers too. EDIT: wrong post........
But why is the R7 2700X in the list instead?
Desktop benching:
was deciding between r7 2700x and r5 3600 and forgot to change it on pc part picker lol
think you got the wrong post dude lol
then MSI B450 Tomahawk Max then, normal Tomahawk is fine if you dont mind the simplified UEFI design.
Desktop benching:
B450 tomahawk Max is what I would get and don’t worry about overclocking the 3600, you won’t get anywhere with it. They have them pretty much maxed out from the factory and don’t overclock worth a damn.
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
