Ive made a build plan for a budget of something arround 1200€ I am posting here just to get more opinion. Im still in doubt about 1. the graphic card because de AMD RX5700 TX is way cheaper but I am afraid of the performance difference, and 2. the powersupply I think it may be a bit overkill for this build? What do you guys think?
My aim is to play games at 1080p in a 144Hz monitor.
https://linustechtips.com/topic/1147391-europe-build-plan/
The 2070S is usually still better than the 5700XT, of course not counting scenarios where one is obviously better.
I think you didn't post your full list, there is no PSU in the list.
It's always helpful to just post your PCPartPicker link, that way people can edit the list.
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232196
You have no PSU listed on  this build?
I would not recommend that CPU. I'd recommendd a 3600(x). And the 5700xt preforms exceptionally for the price. I would recommend it over a 2070Super
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232201
Where would that be (RX5700 being better)?
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232209
Your saying a i5-3600(x) right?
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232215
No. Not intel
The AMD Ryzen 5 3600. Or 3600x. Or if you're up for the money the 3700x.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232217
is the  AMD Ryzen 5 3600 better than the i5 or is just if I switched to the AMD RX?
The AMD RX?
And yes, I would say the new Ryzen is better than old intel. I'd say it's better than new intel...
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232325
9 minutes ago, Statik said:
The AMD RX?
What I meant is if youre saying that its better just performance wise or just because I would put a AMD GPU or it doenst matter at all that they were both to be from the same brand
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232341
I think overall it's just a better CPU. It does not matter if your GPU and CPU are different brands. It won't effect performance.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232346
I'll recommend something like this instead....
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€193.90 @ Mindfactory)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  (€92.89 @ Mindfactory)
Memory: Patriot Viper 4 Blackout 16 GB (2 x 8 GB) DDR4-3600 Memory  (€88.80 @ Alza)
Storage: Sabrent Rocket 1 TB M.2-2280 NVME Solid State Drive  (€119.99 @ Amazon Deutschland)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (€395.90 @ Mindfactory)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  (€72.81 @ Amazon Deutschland)
Power Supply: BitFenix Formula Gold 550 W 80+ Gold Certified ATX Power Supply  (€69.90 @ Amazon Deutschland)
Total: €1034.19
Generated by PCPartPicker 2020-01-21 05:02 CET+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13232829
The 5700XT will almost never be better than a 2070 Super, but there are exceptions like BFV and Metro Exodus:
https://www.guru3d.com/articles_pages/msi_radeon_rx_5700_xt_gaming_x_review,13.html
https://www.guru3d.com/articles_pages/msi_radeon_rx_5700_xt_gaming_x_review,15.html
But in general the RTX 2070S is stronger, but I didn't want to say one is "always" faster/better.
As for the build itself, looks okay, but I would strongly suggest a Ryzen 3600 build like the one @VEXICUS suggested. The Ryzen CPU has more threads and better single-core performance, making it a better choice for (basically) all purposes.
The upgrade to an M.2 NVME is also nice to have and the PSU is just a better choice.
Plus if the price difference is large(r), the 5700 XT is actually a CPU that makes a lot of sense.
https://linustechtips.com/topic/1147391-europe-build-plan/#findComment-13233679
