Got a few questions about power supplies.  Firstly what is the main difference between the form factors?  An article I read on Newegg (https://www.newegg.com/insider/how-to-choose-a-pc-power-supply-buying-guide/) that says the main ones are the ATX12V and EPS12V but I don't really understand what the difference is outside of different connector types.  Also for the motherboard I want (https://www.gigabyte.com/us/Motherboard/X570-AORUS-ELITE-rev-10#kf) it says it has both 24 pin and 8 pin connectors but only shows one connector in the picture.  Would both types just plug into the same spot?
Is there any real benefit to using a hardwired PSU vs a modular/hybrid?  Like how much more likely is it that a modular plug is gonna go bad versus a hard wired one?  I figure this is more down to the manufacturer but still.
How important are the higher level 80 PLUS ratings?  Would having a lower rating like bronze or silver have any negative effect vs a plat or titanium or is it just how much you wanna spend on the electric bill?
How do I determine if the 12V rails have the right wattage?  I've heard that they can be labeled differently on different PSU's and the labeled wattage doesn't always add up to the real total wattage so what should I be looking for?
https://linustechtips.com/topic/1147010-power-supply-questions/
size, get wht your case supports
You need both a 8 pin and 24 pin, every modern psu has this.
cheaper. Failure is uncommon and effiency difference is tiny.
Really just small power bill savings, probalby won't pay off. But normally higher 80+ is a just better built psu, but not alwys.
Whats youre system build?
YOur probably overthinking this. NOrmally just get a good 500-700w and your good.
https://linustechtips.com/topic/1147010-power-supply-questions/#findComment-13228999
Size and mounting way. Pick the one your case supports. Usually that will be ATX, but maybe SFX.
Well that is the difference. The connector and thus the power that goes through it.
The 24 pin (ATX) is also what is used to turn on the PSU and is general board power, while the EPS is CPU power.
They plug in here:
The benefit of modular is just ease of installation, or rather ease of cable management.
They don't tend to go bad, but you will have a warranty regardless.
The rating itself is not that important for quality, but only for power usage, but the difference won't be huge.
If you want more info, read this:
But the general gist (on 230V, 100% load):
Bronze = 85% efficient
Gold = 89% efficient
Titanium = 94% efficient
Those won't be very large improvements, but may lower your power bill a couple of euros/dollars/whatever a year.
Don't choose a PSU based on efficiency though, pick a good one. 80+ is not an indication of quality, merely indication of efficiency. There are bad 80+ Gold units and good 80+ Bronze units  and vice-versa.
Most people won't have to worry about this at all, unless you're running weird configurations/heavy power draw components (like multiple GPU's or HEDT CPU's)
https://linustechtips.com/topic/1147010-power-supply-questions/#findComment-13229006
Apart from saving a bit on power, it can also make the PSU quieter. Potentially by quite a lot, but it also depends on the heatsinks and fan.
Going from eg. 80% efficiency to 90% efficiency only saves you 11% on your power bill, but it cuts the heat generated inside the power supply in half (imagine the difference for a GPU or CPU cooler if you cut power consumption in half).
https://linustechtips.com/topic/1147010-power-supply-questions/#findComment-13229101
I'm a bit a way off from saving enough $ so things might change.
https://linustechtips.com/topic/1147010-power-supply-questions/#findComment-13229106
