Radeon RX 5700 XT Gaming X doesn’t fit in h500
LambIV
4 minutes ago, LambIV said:
Please help this is my first build.
Not sure why it wouldn't fit that video card should be 290mm in length and the nzxt h500 specs 381mm for video card clearance. So even if you had an aio with fans you should still have about 326mm for video card space. You'll have to explain further as to what exactly isn't fitting. Is the card hitting something? Is it just not going into the slot properly? Pictures would be a great help.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
pictures?
Desktop benching:
5 minutes ago, Jurrunio said:
pictures?
Yea I mean there is that saying "A picture is worth a thousand words" If they can't tell us why it won't fit they could at least show us so we can try and help.
Cosmos Sv2:
  • OS: Win 10 Pro
Old School AMD:
  • GPU: XFX HD 7950
  • PSU: Corsair 650W
Hopefully these photos help, tell me if you need more detailed photos.
It’s the bit of the mounting bracket that sticks out on the graphics card preventing it mounting flush with the casing.
You should remove the top 2/3 brackets and insert the card at an angle, the brackets on the card shouldn't prevent it from going in. Use the top slot on the mobo.
