epson xp352, problems with scans
Hi, I'm having hard times to figured out how should I get to work the scan function via wifi/wsd (I didn't try via cable, because the printer is to distant from the pc)
from the printer scan -> wsd -> I select my pc -> the printer reloads the windows, and there is no longer my pc displayed, I reload the window, and I get the same problem;
meanwhile if I reboot the printer I get the same problem as before
with the epson drivers, I cannot figure out what does what, since everything seem to be a stuck screen without any context
https://linustechtips.com/topic/1145429-epson-xp352-problems-with-scans/
