Silverstone TJ08-E vs Nanoxia Deep Silence 4
Solved by airdeano,
Was it a huge temperature difference between the define and the arc? Also, if I decide to get the arc mini r2, I'll have to move from the 770 to an R9 280X. Is that ok?
moving from the define to the arc, yes at least 8° or more on CPU. using the same
fans and same placement. you rig will be only as loud as the noisiest component.
shouldn't be an issue for temperatures. it's just going to be a hot card. using the
DCUII or TF should make the GPU temps more "livable" on the 280x. and having
the arc case will move that heat easier due to the open front intake.
