Need recommendations: 1440p,144hz, monitor
LoneWulf14
So I'm going to be building my PC soon with a RTX 2070 super and I need a monitor to run at 144hz at 1440p with G-sync, any recommendations? Thanks in advance.
Budget? The low-end is around $300 and the highest practical tier is around $500.
Ryzen 5 1600 @ 3.8Ghz w/ Arctic Freezer 33 Tower Cooler | MSI B450 Tomahawk |  32GB Crucial Ballistix DDR4 3200MHz CAS 14
Sapphire RX 5700XT Pulse | EVGA 650w GQ 80+ Gold Semi-Modular  |  XPG SX6000 512GB Nvme SSD | NZXT H500
Acer XF270HU - 1440p 144Hz Freeesync IPS | Corsair Strafe - Cherry MX Red  |  Logitech G502
I have a few questions.
First is budget?
Second is what type of panel you want? TN, VA, or IPS?
Third is what are you mainly going to use it for? Gaming, Work, or Watching TV shows and movies?
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
Just now, leo1798 said:
Budget?
I'm in the UK so around £400 but I'm flexible if the performance of the monitor is really worth the price.
No real preference here, My old PC's monitor was a TN panel but I've heard a lot of people saying that IPS monitors have been getting a lot better on response times so I don't really know.
Mainly used for Gaming, I do watch some tv shows on my pc from time to time.
2 minutes ago, LoneWulf14 said:
-snip-
The Dell S2719DGF is a TN panel that is pretty good and reliable. If you want an IPS monitor, you could try the BenQ EX2780Q. It's only 20 pound over budget. Heard it's really nice but do not use HDR as it's only HDR400 and looks horrible. Also, this next monitor is out-of-stock online in the UK but if you can find it for anywhere around 380-420 pounds (might have to check local stores), the LG 27GL83A would be a better choice than the BenQ.
MAIN PC:
SECONDARY PC:
If you want 1440p 144hz and g-sync/g-sync compatible your only options will be the LG 27GL83A or Pixio PX7 Prime, both are very similar but i think the LG one has better response time. I think these two are the best bang for the buck if you're going for 1440p 144hz.
CPU: Ryzen 5 5600x | MB: Asus TUF Gaming B550-Plus | RAM: Crucial Ballistix RGB 16Gb 3200Mhz | GPU: Gigabyte GTX 1080 Windforce | Cooler: Scythe Fuma 2 | PSU: EVGA SuperNOVA 650 G2 | SSD: Crucial MX300 275Gb | HDD: WD Black 2Tb | Monitor: LG 27GL83A
