RTX 2060 running in x8 mode instead of x16
Go to solution Solved by Jurrunio,
Take the card out and stuck it in again, long connectors like the PCIe x16 slot are notorious for being hard to get it in right the first time.
Recently I've discovered that my graphics card is running in x8 PCI-E Lanes Mode. I'm afraid that this comes with a performance penalty. I have replaced my GPU thermal paste aprox. 1 month ago (because the card was hitting even 80*C under load). My specs are:
CPU: Ryzen 5 2600X
MOBO: Asus ROG Strix B450-F (newest bios)
GPU: MSI RTX 2060 GAMING Z (with OC)
STORAGE: 953GB Patriot Viper VPN100 M.2 NVME (x4)  and  223GB INTEL SSDSC2BW240H6 (SATA)
My latest userbenchmark run:
https://www.userbenchmark.com/UserRun/23502893
(Yes, I know that userbenchmark is unreliable but it shows performance compared to other users)
Ryzen 2nd gen supports 24 PCI-E gen3 Lanes (4 are used for chipset communication). In theory I should be able to get full bandwidth out of my GPU and NVME (x4 + x16). Is there something that I'm missing?
stupid question maybe, but what pcie slot are you using?
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
The one closest to the CPU (it's labeled PCIEX16_1 in the manual)
never mind then, just wanted to make sure...
know someone that intalled it way down in the last slot b/c it looked "cooler"
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
What software are you using to verify the PCIe link? Are you checking both idle and load status of the connection?
Primary PC:
Trash beauty:
Xeon X5560RX 570 4GB (defective) -Fattydove Racing 240GB - WD Blue 320GBHP Z400 - 6x2GB DDR3 1066 - EVGA 450W3
CPU: Ryzen 5 2600X
Try checking your BIOS PCIe settings.
Do you have a second PCIe x16 slot on your motherboard?
Do what he said I think that this will solve your problem.
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • Laptop --> Dell Inspirion 15 7567 - i5 7300HQ - GTX 1050 4GB - 8GB DDR4 - 1TB - 256GB
Better than that, just check which slot the NVMe drive is in. On the B450-F (I had one, well have it now because the rig has worked its way back to me for eventual troubleshooting) the top NVMe slot yoinks lanes from the main 16x PCIe, IIRC you need to use the bottom slot to avoid that (I always ran my WD Black NVMe in the bottom slot for this reason).
As for the performance penalty, naaah even a 2080 Ti can't max a PCIe 3.0 x16 connection, a 2060 shouldn't have issues with PCIe 3.0 x8. Heck when I ran SLI 1080s they were in x8/x8 (those are faster cards too, closer to/the same as a 2070) and there was no performance penalty.
Main PC:
CPU: i9 7980XE @4.0GHz/1.11v
Cooler: EVGA CLC 280 w/Noctua Redux NF-P14s fans
Motherboard: EVGA X299 Dark
RAM: 4x8GB HyperX Predator DDR4 @3200MHz
GPU: Intel ARC A770 LE
Storage: 1TB 970 Evo  + 1TB MP34 + 1TB MX500 + 500GB XPG Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40 + Lite-On IHAS124-14
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow + 3x Noctua iPPC NF-A14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2015 15" MacBook Pro (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, swapped to 128GB SD card and running Rockbox firmware), Nintendo Switch
As someone else mentioned, it could be because of where you installed your SSD.  Sometimes that can cause a PCI slot to operate at x8.
One question though, do you even gain anything from the 2060 being on a x16 slot.  My understanding is that it won't even saturate the bandwidth of a x8 slot.  If that is true, it might not even be worth the hassle of trying to figure out what is wrong.
Whoah... Can not belive it was something that dumb... Took the card out, cleaned the PCI-E connectors with ethanol poped it back in and the card shows up as x16 in the BIOS and in GPU-Z. Must've messed something up when I was installing my NVME. HWinfo reports my GPU as x16 and M.2 as x4.
Ironically it's in the top slot and works just fine, although I've had my fair share of troubles with this board. It had alot of weird quirks (not being able to shutdown/reboot properly) but after I flashed the newest bios (v3003) everything seems to be working just fine.
Anyways, thanks to you all for your help!
