What games? What CPU? What speed is your RAM running at? What PSU do you have?
https://linustechtips.com/topic/1143241-help/#findComment-13198604
For starters how about give us more information like what are you full specs, how did you validate the usage of the GPU... if you have checked temperatures or had any hardware change recently and the state of your OS.
Does the problem happens on every game?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1143241-help/#findComment-13198606
Games: R6,Dayz,Doom I checked the temperatures
CPU: Ryzen 7 2700x 4.3GHz OC
MOTHERBOARD: Gigabyte X470 Aorus Ultra Gaming
GPU: Gigabyte GTX 1660 Super 6GB OC x3 fan
RAM: 8GB RAM
PSU: TX-Series ZM500-TX 500w (Blue Led)
HDD: Toshiba - 1 TB 7200 rpm
SSD: Kingston - 120gb 520gbs 420gbs
M.2: Kingston - 500gb 1500gbs 1500gbs
https://linustechtips.com/topic/1143241-help/#findComment-13198613
try to use the msi afterburner overlay in games to see real values of cpu and gpu utilisation.
if you only have 1 stick of ram, you're losing a lot of performance there, as dual channel is important.
check what power plan you are on.
check temperatures of gpu and cpu while gaming.
https://linustechtips.com/topic/1143241-help/#findComment-13198679
Well two things could be your issue... either your OS drive is bad (Kingston SSD are notorious for being crap) or your GPU drivers are broken.
Your first troubleshooting should be DDU in safe mode and reinstall the GPU drivers fresh new... do download the latest drivers in advance and once you finish DDU'ing in safe mode reboot without connecting to the internet and install the previous downloaded drivers since Windows Update might try to force DCH drivers.
Personal Desktop":
https://linustechtips.com/topic/1143241-help/#findComment-13198730
3 hours ago, Bull8t said:
RAM: 8GB RAM
Is it single stick? This may be a problem as well, Ryzen benefits quite lot from dual channel fast ram
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1143241-help/#findComment-13199188
