Hi guys,
Been trying to sort this issue out for a while with no success. My PC is making a faint knocking sound. Sounds like a clock ticking faintly and it's doing my head in. I've changed the front fans out with different ones and each time the sound persists. It's not my HDD and is not coming from my GPU. Could this be a sound coming from my CPU cooler (NZXT X42) or possibly an issue with my SSD. Any help would be appreciated.
Thanks,
CJ
https://linustechtips.com/topic/1139599-pc-making-a-knocking-sound/
What pump profile do you have set on the AIO?
Asetek pumps tick on quiet mode.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
can you pinpoint where in the case the sound is coming from?
is the sound "rythmical"? how long are the pauses between the "knoks"?
the only things i could imagine, since you ruled out all your fans and your HDD, are your AIO-pump or your PSU.
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
1 hour ago, MrCJLambert said:
Hi guys,
Thanks,
CJ
It's probably your HDD.  Tried removing it and check if the noise is gone?
My SEAGATE Barracuda sounds like a mixture between coffee machine and coffee grinder,  so I can definitely see someone describing as "faintly ticking clock" as it would still fit.
Note: my Toshiba SSHD doesn't make these noises at all,  just occasionally normal, as I would describe it "HDD sounds"
So did you actually remove your HDD (brand?)  to check?
1 hour ago, emosun said:
turn the machine on and unplug things until the knocking stops
Basically..........
-Scott Manley, 2021
  • 9 months later...
So I found out the source of the issue. Basically it was my AIO. I'm now running a X62 in a new ITX build and I had the same issue. I had the rad mounted with the tubes at the top. Flipping it around solved the issue. Thanks for your help and sorry for the lack of responses lol.
