Hello. I’m having trouble installing my graphics card.
I am using this PSU and my card requires 8-pin PCIE power connection.
I’m not sure if my PSU has the right connections for this. I have a 6–8 pin adapter, but it requires a 6-pin PCIE cable which I can’t seem to find on Amazon.
Any ideas on how to go about this?
https://linustechtips.com/topic/1139236-help-with-installing-gpu/
You should have a 6+2 pin pcie connector with that PSU. Plug that in to the 8 pin on your GPU.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
Hi there, this is the cable that came with your PSU that you're supposed to use.
It's weird to me that you defaulted to trying to find adapter cables on Amazon, instead of looking into what cables your own PSU's got.
6 minutes ago, OrionFOTL said:
So, any follow-up to this?
Hi. I actually ended up buying a new PSU (from Amazon lol). Other users advised that the CX430M is not suitable for a GPU that needs a 6+2 pin. In any case, I’ve lost all the original cables and didn’t feel like waiting around for replacements.
Thanks for your help and follow up.
