Usually those without 0rpm is 2nd/3rd grade cooler, why would you want that?
my last 5700xt had issues, fans not spinning sometimes and high temps, i really worried now i think that the problem was because of the 0 rpm mode
Did you isolate software issue?
tried to ddu the driver couple of times and installed every driver possible, still same results, fans sometimes not spinning and reporting wrong RPM, gpu overheating and reaches above 50C.
already returned the card.
7 minutes ago, NineEyeRon said:
Can this be turned off in the latest software?
Can  you just adjust the fan profile?
1. i dunno, afaik there wasn't an option to do that
2. yes already did that, same results the card completely ignoring the fan curves i've set
Just turn the 0 mode off.
Make a custom fan curve is even better.
·Ï¢årµ§·
i7 4790k · 32GB Kingston HyperX · MSI Gaming 5 · ... · 30" HP ZR30W + 27" Samsung 275T · 2x240GB Intel 530 in Raid 0 + 2x1TB Crucial MX500 · Lain-Li X2000F · Antec Signature SG-850 · BeQuiet! Dark Rock 3 Pro · Logitech Z5500 · Win10pro 64bit
