Threadripper 3970x Cooler - Do I really need liquid?
Solved by Guest,
7 minutes ago, Guy Marshall said:I have checked and it doesn't seem to have full coverage fo the heat spreader, and instead looks like a generic adaptation. Also a lot of the reviews complain about loud fans. I have seen people use the Kraken X62 which also isn't full coverage, just wondering if you have any experience with that cooler.
It does. I neglected to mention it's the specific TR4 variant, not the regular model. I never used the stock fans, so I can't comment on fan noise. I don't like NZXT Cam as its a resource hog, so I've never bothered with their coolers. It's a standard Asetek though, so it probably performs well enough. Though as you know it isn't full coverage.
