Good afternoon focks, I am new to using this but I was wondering if I could get your support. I have a Clevo 230st Gaming notebook which has an Intel i7-4700MQ and an Nvidia Gtx 765m however, I am having some issues with the graphics card. This being that if I update to the latest Nvidia drivers my pc crashes with video TDR faliure or freezes because of consatnt GPU spiking. I have previously used the Clevo website nvidia driver but they have never been updated so they are from 2015 so I am unable to play the modern games I want to and I know my laptop can run. So I hope that someone out thier can help me. I have tried all the forums online and nothing seems to help.
Kind Regards Joshua
https://linustechtips.com/topic/1137377-help-please/
For most notebooks you can only use the manufacturer's drivers and the official drivers won't work. It's also possible the newest drivers no longer support that GPU, so you'd have to check which version of the Nvidia drivers is the last one to support the GTX 765m.
https://linustechtips.com/topic/1137377-help-please/#findComment-13152641
don't update to the latest try a few versions back.
try 419.67 or 419.35
Edited by GDRRiley
added drivers
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1137377-help-please/#findComment-13152642
Just now, Eigenvektor said:
For most notebooks you can only use the manufacturers drivers and the official drivers won't work. It's also possible the newest drivers no longer support that GPU, so you'd have to check which version of the Nvidia driver's is the last one to support the GTX 765m.
i've always ran official drivers but it comes down to brands.
https://linustechtips.com/topic/1137377-help-please/#findComment-13152643
I've only had HP notebooks, so that might be the issue, because I could only ever use their old/outdated drivers and never the official ones. Could also just be an AMD limitation though.
https://linustechtips.com/topic/1137377-help-please/#findComment-13152646
Im running a newer probook with brand new AMD drivers.
Ive ran an MSI gtx 1050m, asus gt635m both were always on the latest
https://linustechtips.com/topic/1137377-help-please/#findComment-13152648
Good to know. I've had two older HP mobile workstations (nx9420/8740w) and AMD never supplied drivers for them, I was always limited to HP's.
https://linustechtips.com/topic/1137377-help-please/#findComment-13152663
My HP laptop (Ryzen 3 2200 with Vega) is running perfectly with Adrenaline 2020.
Kind Regards Joshua
This. I'd also recommend you DDU the system and clean the Nvidia drivers properly before trying an older version.
Main Rig:-
Server:-
https://linustechtips.com/topic/1137377-help-please/#findComment-13152671
2015?
Sounds like you need to clean install windows.
Then the new drivers will probably work correctly.
https://linustechtips.com/topic/1137377-help-please/#findComment-13152672
6 hours ago, Enderman said:
2015?
Have done a full install of windows and It doesn't like the new nividia drivers the problem is the ones from Clevo website are outdated now form 2015
https://linustechtips.com/topic/1137377-help-please/#findComment-13153263
Yep I have tried it only works with the ones on the clevo website but they are outdated now because they are from 2015 so I tried the latest ones and nothing just TDR faliure and spiking. Tried reinstall and nothing worked
https://linustechtips.com/topic/1137377-help-please/#findComment-13153269
Don't use ones from the laptop website, use geforce experience and let it install them.
https://linustechtips.com/topic/1137377-help-please/#findComment-13153530
