Hi,
My 9900KF should be here tomorrow and I was wondering with direct die cooling, how much difference will using Conductonaut vs Kryonaut make (or similar)?
I was going to use either nail varnish or liquid electrical tape to cover up the vulnerable areas on the top of the cpu and use Conductonaut
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
https://linustechtips.com/topic/1134068-9900kf-direct-die-cooling/
Are you aware that the i9 9900KF IHS is soldered?
Personal Desktop":
Luna, the temporary Desktop:
It's still rather easy to delid after some heating-up. Like, run it at 90° C in stress-test for 30 minutes beforehand.
Tag or quote me so i see your reply
Yep, I was just going to heat it up with my soldering iron in my delidding tool
Does it worth it or not depends on your intentions, if you want to do some extreme-ish OC and have appropriate cooling system then go for it, there are some difference. If you will just casually game on it then just OC it to 5GHz, thermals will be okay in gaming even with some mid-range air cooler.
Oh, that's bad idea, you can damage the IHS, at most you can use heat gun but preheating it with it's own heat output will do just fine and it's safer.
It's more really just for hobby/project purposes, I was just wondering how much difference the paste (liquid metal vs traditional) makes in direct die with a der8auer OC-Frame
I don't want to search for sources, there are plenty i'm sure but IIRC that's just about 5°C maybe and it depends on the load and cooling system of course.
I've got a d5 pump, 2x 360mm radiators and a xspc raystorm block ready to fit. Im also waiting on RDNA2 release, hopefully at CES in Jan, before I upgrade or buy a waterblock for my current 1080ti.
Yep, that should do it lol. Okay, do it, delid it and OC the shit out of it, just don't break it :)
On 12/13/2019 at 8:55 AM, remus243 said:
Hi,
I didn't check on my 9900k last year, nor will I be using normal paste on the 9900ks this year but IIRC the difference between paste and liquid metal is usually double digit temps - liquid metal is much much more conductive than Kryonaut.
Also - if you're going to the trouble of delidding a soldered CPU for direct die, doesn't make sense to me to skimp on the TIM since you're going for lowest possible temps in the first place...
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
I'll test to see if it's a good cpu first though ;)
