New to this. Some help would be nice to part this together.
Ultimately just want to play fortnite and rocket league with my kid at high fps, also some modern warfare. Budget I would like to max at about $1000-1200.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($189.99 @ Best Buy)
Motherboard: Asus ROG STRIX X470-F Gaming ATX AM4 Motherboard  ($165.98 @ Walmart)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($64.99 @ Best Buy)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($62.99 @ B&H)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: Asus GeForce RTX 2060 6 GB STRIX GAMING OC Video Card  ($389.99 @ Newegg)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($45.98 @ Newegg)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($69.99 @ Monoprice)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($106.99 @ Other World Computing)
Monitor: AOC G2590FX 24.5" 1920x1080 144 Hz Monitor  ($159.99 @ Amazon)
Total: $1296.88
Generated by PCPartPicker 2019-12-12 07:24 EST-0500
https://linustechtips.com/topic/1133694-first-ever-build/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122326
I would change the PSU for a TX550M and change the GPU for either:
- a 2060 Super for a bit more, if you want to stay Nvidia
or
- a 5700XT
Looks good to me otherwise.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122331
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122345
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($99.99 @ B&H)
Memory: OLOy 16 GB (2 x 8 GB) DDR4-3000 Memory  ($49.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($399.99 @ Newegg)
Case: Cougar MX330 ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($69.98 @ Amazon)
Monitor: Acer VG271 Pbmiipx 27.0" 1920x1080 144 Hz Monitor  ($209.99 @ Amazon)
Total: $1174.91
Generated by PCPartPicker 2019-12-12 07:39 EST-0500
pick up a windows liscence as a grey key or just from your prefered vendor. this will be just about as good as it gets.
https://pcpartpicker.com/product/LmCFf7/arctic-p12-pwm-pst5-pack-563-cfm-120-mm-fans-acfan00137a
here are a bunch of extra fans to utilize the airflow oppertunity.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122358
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122359
2 minutes ago, GoldenLag said:
-Build-
Nice one
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122361
2 minutes ago, DoctorNick said:
CXM is worse than CX. due to coil wine reasons id avoid it.
also its fairly costly compared to like PP10 or PP11 options or just the cx550.
10$ more you get the excellent Phison E12 drives.
edit: for future reference, the drives are the A80, inland premium, Sabrent rocket (assumign they didnt switcharoo), MP34 and some more i dont recall atm.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122362
Nice information! Actually thought it was also a Phison E12, but I totally agree, then your suggestion is the best.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122398
it could be a phison E12. i havent doublechecked that
i can only remember X many drives.
doublechecking.........
Dramless, Realtek controller: "Realtek RTS5763DL"
so not a Phison E12. those ones have a Dram cache to write to.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122404
26 minutes ago, DoctorNick said:
This looks great, Thanks to everyone who replied with help super quick. Only question is with the B450, will I need to update the bios for the r5? Only been researching a few days and I've noticed a ton of people recommending the tomahawk max due to not needing to flash the bios?
I'm a noob, so chances are I'm 10% correct haha.
I believe I read about the cxm being bad on the forum in someone else's build.
Not sure what E12 is  or which power supply would be better to replace the cxm with. Just a standard 550-600W bronze 80+?
I have no preference over gpu's. Just kind of Frankenstein'd parts from different peoples builds/videos with my very limited knowledge.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122409
CX550. the non-m which is different than the CXM because Corsair is just yes. i dont know why, they just did.
B450m AC from ASrock and MAX boards from MSI do not need a Bios update.
Total: $1174.91
Generated by PCPartPicker 2019-12-12 08:20 EST-0500
this is more or less complete with the fans i linked earlier as a optional adition that will help with airflow.
the monitor is also really good as an IPS panel for good colors and decent speed. and good 350 nit brightness to make the colors it make more vibrant.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122426
Yea that's correct. @GoldenLag is the PSU king of LTT forums - E12 is the SSD controller - Buy this instead as golden suggested - Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive
Actually consider buying GoldenLags build as it's pretty solid!
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122428
Total: $1174.91
Awesome, thank you!
Thanks to you both, is there anything I could possibly need? Or would I be able to just buy all the parts, build it and be on my way, take for granted I don't yardsale anything along the build lol
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122433
i'd buy a 5 pack of arctic 120mm pwm fan to go with the fan already included with the case. fit 3 on the front as intake, and the one at the back and 2 on top as exhaust.
1 hour ago, boggy77 said:
I'd go with the ram I suggested. for $25 more, which is 2% of the cost of the build, you might get 5% more fps.
If you want to overclock in the future, or want a more silent system, you might want to go for a cpu cooler such as the bequiet dark rock pro 4.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122450
" motherboard M.2 slot #1 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6.0 Gb/s ports are disabled"
is this something I need to worry about? I have absolutely no clue what this means aside from what m.2 and sata generally are.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122451
I was planning on going with the ripjaw ram that was suggested, as this is my first build and I know very little about what I'm doing.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122453
press X to doubt
but i agree with him nonetheless here, as usual
and the cx is better because it uses a Half Bridge Resonant LLC, compared to CXM's double forward
which is for what you should know just better and less likely to whine
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122457
Grab the fanpack and maybe get a fanhub. Tho iirc it should have enough fanheaders to cover most.
Maybe an HDD down the lines, tho 1TB lasts quite some time.
Not something to worry about.
That goes for the chipset M.2 iirc. Not the CPU lanes.
If im wrong its such a minor change anyways. There is plenty of Sata even without the 2 Sata ports.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122458
unless you're planning on having 5 HDDs, you're fine.
the 5 arctic fans i recommended can be daisy chained, so no need for a fanhub.
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122462
Total: $1174.91
Alright, going with this. Just switching out the ram for the suggested ripjaw 3600, and got the extra 5 fans. Is there anything else that I'll need before I checkout?
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122591
at 27in, 1080p is not very crisp. I'd go with a 24in monitor at 1080p or 27in at 1440p
https://linustechtips.com/topic/1133694-first-ever-build/#findComment-13122619
