Best overclock settings for evga 1070ti sc black?
Every GPU is different, it's called silicon lottery. Give it a whirl, find out how far it goes.
A mediocre Pascal overclocker will go a bit above 2000, a decent OC is above 2100, and a great OC is 2200+
Primary PC:
Best place to start?
Pascal voltage is locked so power limit and frequency is all you get. Go ahead and max power, slap +100, see what happens.
Primary PC:
So using unigine heaven benchmark 4.0, 3840x2160 at high settings, the difference was minimal.
Pascal voltage isn't fully locked per-say, it just has very little room to tune above stock specs. If you have a card with a high enough power limit vbios you can take advantage of it, typically a pascal card will hover around the 1.043v mark with jumps to 1.063 dependent on power limits, temperatures, and level of demand. By raising the voltage, the card is given access to a voltage bin that is otherwise never used by a stock card, specifically ending at 1.093v. For instance, my 1070 ti gaming cannot take advantage of this since my vbios limits me to around 220w so that leaves me stuck around the 2050mhz mark for my particular card.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
