Need recommendation for cheapest safe psu
Go to solution Solved by porina,
Not sure I can find the reference again, but the CX are "better" than the equivalent CXM and usually cheaper. 450W is plenty for the proposed system. Depends on local pricing and availability, but certainly CX450 would be on my shortlist.
Most of my "budget" builds use CX or CXM series.
For a stock 8350k, h310, two SATA drives, 5x fans, and a low to midrange gpu like a 1660/RX 5500.
Doesn't need to be fancy.
Was looking at the Corsair CX450, but even those are like $60.
Obviously if I can't get away with something cheaper I'll go for it.
But open to suggestions.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
https://linustechtips.com/topic/1132582-need-recommendation-for-cheapest-safe-psu/
I would invest a bit more from you'r choice Corsair CX450 and a minimum of 550w.
The Corsair TX-M Series TX550M is a better choice.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
450W are okay, this build will consume no more than 150W.
Corsair CX450 are 50$ on Newegg so it's my recommendation too.
Tag or quote me so i see your reply
Seems the cx650m is $1 cheaper the cx550m rn do I guess I'll buy that.
Corsair CX Series 650 Watt 80 Plus Bronze Certified Modular Power Supply (CP-9020103-NA)
https://www.amazon.com/dp/B01B72W1VA/ref=cm_sw_r_cp_apa_i_4SD7DbPVVTR5N
@Juular is this a good one?
The tier list is a bit confusing I do t know of this is B or B+ or whatever.
@Princess Luna do you know if
Corsair CX Series 650 Watt 80 Plus Bronze Certified Modular Power Supply (CP-9020103-NA) https://www.amazon.com/dp/B01B72W1VA/ref=cm_sw_r_cp_apa_i_4SD7DbPVVTR5N
Is good ($1 cheaper than 550) and what tier is this in?
Thanks
See, PSU prices are very weird recently, Corsair CX550\650 doesn't worth 70$, get Phanteks AMP 550W then for 80$, it's top-tier PSU, 550W are enough for almost any gaming build (except for RTX2080 Super \ Ti).
There were Corsair TX550\650 for 70$ which would be a good pick, or Corsair RMx for 80$ also, some other choices like CM MWE Gold for 60-70$ but after recent sales all these units spiked in price, tariffs probably. But Phanteks AMP (which is rebranded Seasonic Focus) for 80$ is a good deal too.
What retailer has this one for $80?
Thanks for the suggestions.
It's definitely not going to be a high end system. It's for my daughter with some leftover parts, but mainly I want today focus on pretty lights as that's her main focus.
It will likely be using integrated graphics for a while even.
Newegg, it's -10$ rebate tho
https://pcpartpicker.com/product/Y3bCmG/phanteks-amp-550-w-80-gold-certified-fully-modular-atx-power-supply-ph-p550g_us01
Thanks
CXM uses outdated topology, it's not a terrible PSU but there's better stuff like the phanteks linked above.
The normal CX that's not semi/modular is actually newer and a reliable choice on the cheaper side but seems like PSU pricing is all over the place lately due to the new import taxes USA has with China.
Personal Desktop":
Luna, the temporary Desktop:
Thanks for the info.
Also @porina and the others.
Went with the CX 550 (non m) at $69, as it's only $10 more than the 450.
Tried finding the others on Amazon (preferred retailer) without success, so just went with that.
Should last a while and through a few upgrades later on.  Thanks again.
