Where to buy custom sleeved cables for a power supply?
Gauzl
I'm looking for a full kit of blue or black sleeved power supply cables for a cooler master gold silent pro 800w.
sleeved to the PSU or extentions? As noted above by Tea1337 and xxMichael, you can grab extensions from BitFenix that clip on to the end of cables so the last 30cm of cabling is sleeved (the idea being as you usually only see the last 15cm of cable and the unsleeved bit is behind the mobo tray). You can order full length custom sleeves but expect to pay north of $100
I mean i want new cables to replace the ones the power supply came with, I'm not after extensions.
Depends on the PSU.
@ ericlee30 might just be able to help you soon
