MOBO : ASRock b365m Phantom Gaming 4
CPU : i5 9400f
GPU : GTX 980 Asus Strix 4G
RAM : 2x 8GB G.Skill DDR4 2400Mhz (16GB)
SSD : Samsung 860 Evo 250GB
CASE : Tecware Nexus M (Black)
PSU : 600W 80Plus
COOLER : Sliverstone td02-RGB AIO Cooler
Building it help me check if the parts are compatible thanks alot :D
https://linustechtips.com/topic/1131675-help-see-if-parts-are-compatible/
CPU : i5 9400f
PSU : 600W 80Plus
Yes all fine. What PSU is that? Model?
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
13 minutes ago, LIGTHIN said:
EVGA 600BR
You're all set!
Any reason why you go with Intel instead of AMD?  You'd get more value for the money.
ex Intel 9400f is about as powerful as a Ryzen 1600 which you find for as low as 80$ (60$ at Microcenter if you buy it with a motherboard)
The Ryzen 1600 also comes with a decent stock cooler, unlike Intel CPU coolers, and you can overclock it if you want to (and pair it with suitable motherboard)
You can use a 50$ A320 based motherboard if you're really on low budget (but no overclocking possible on A320), or you can spend 10-15$ more for a B450 motherboard that will also allow you to overclock the cpu.
Because I already own the motherboard got the f series because didn't need integrated graphics and is way cheaper then other 9 gen processor
Do you also have the ram and everything else?
A motherboard is not that expensive.
You're paying 145$ for a CPU if you get it new, when you could pay 80-100$ for an equivalent CPU, then pay 60$ or more for a motherboard. Then sell the current motherboard and you get some money back.
The motherboard will give you more upgrade options ... you could go up to 12 core / 24 threads with 60-70$ boards in the future:
ASRock B450M PRO4 Micro ATX AM4 Motherboard (B450M PRO4) - PCPartPicker
MSI B450M GAMING PLUS Micro ATX AM4 Motherboard (B450M GAMING PLUS) - PCPartPicker
Gigabyte B450M DS3H Micro ATX AM4 Motherboard (B450M DS3H) - PCPartPicker
ASRock B450M Steel Legend Micro ATX AM4 Motherboard (B450M Steel Legend) - PCPartPicker
