M.2 NVMe not achieving max speed.
Mike.
Hello,
Any advice on this would greatly appreciated.
I have read up on this matter as much as I can but my abilities with computers are limited to be honest.
I have a small MSI PC on which the Motherboard has one M.2 slot.
It came with a M.2 Sata drive which I changed for a M.2 NVMe successfully.
The M.2 NVMe drive claims a max speed of over 3000mbs.
With CrystalDiskMark my max speed was around 1700mbs on the top line for Read, therefore around half the claimed max speed for this NVMe.
With CrystalDiskInfo in the transfer mode section it states -
PCIe 2.0 x4  (as current mode)     PCIe 3.0 x4  (as supported mode)
NVM Express 1.3
It was mentioned to me that PCIe 2.0 x4 might be the problem causing the NVMe to not achieve its max speed and that I should change this to run on PCIe 3.0 x4
I cannot see anything in BIOS for that.
I have read something about the M.2 NVMe being put in to an adaptor and placed in a PCIe slot instead of the M.2 slot.
I'm sure this PC has just one PCIe and that has the graphics card in it.
The PC is very small and wouldn't take anything else inside anyway.
The motherboard has MSI B9181 on it, which I can't find much about.
I suppose I am asking that if CrsytalDiskInfo states PCIe 3.0 x4 is supported - will this board run the NMVe up to much higher than 1700mbs.
Also, how would I do that ie. make PCIe 3.0 x4 the "current mode" instead of PCIe 2.0 x4 ?
Will it not do so with the NVMe drive in the M.2 slot ?
Many thanks.
Mike.
You have it on wrong slot, you have to put it in pci e 3.0 slot on your motherboard.
You can not change it in your bios. If your mobo does not have more slots, it means that your motherboard only has pci e 2.0 slot.
Could work, but since you have only one slot, it does not work,
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
It can also be that your gpu adn m.2 slot divide their power. Some cheap and fairly old motherboards do that. Like in b450 strix-f where the bottom pci e express and pci e 3.0 slot divide their power.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
That's a physical limitation of the mobo. You can't change that.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Just now, Mira Yurizaki said:
Use cases where NVMe's bandwidth shines are rarely encountered in most people's use cases.
True dat! But still people are getting better results with pci e 3.0, not like the 3500 mb/s what they promise, but like 2700+.
If you bought expensive m.2ssd, you should upgrade to ryzen and buy motherboard what supports 3.0. Msi tomahawk max for example.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Thanks SavageNeo, Radium_Angel & Mira Yurizaki for the replies.
I think you've confirmed what I suspected, that being it will have to run as it is.
I thought I would look into it now instead of finding out later it could have run at a higher level all along.
Regards, thanks again.
Mike.
