What is the best watercooler for i7-9700K for 5GHz?
MY RIG
(CPU) I7-9700K (Cooler) Noctua NH-D15 (GPU) Palit GeForce® GTX 1080 Ti JetStream (Motherboard) MSI Z390-A PRO (Memory) Crucial DDR4 2400MHz 2x8GB (Boot SSD) Samsung PM961 SSD 256GB M.2 NVMe (Game Storage) Seagate Barracuda 1TB 3.5'' HDD(Bulk StorageSeagate Barracuda 1TB 3.5'' HDD In Raid(PSU) Corsair CX550M (CASE) Fractal Design Define S Black Window
Arctic Liquid Freezer 2 280 AIO outperforms most of the competition for under 100$. One of the few liquid coolers that uses new AIO tech, has better temps than the air coolers, and is made by a reputable company. They give you a 2 year warranty on purchase. https://www.tomshardware.com/reviews/arctic-liquid-freezer-ii-280-all-in-one-cpu-cooler,6376-2.html
280mm rad is the way to go. They can be quieter and as good as some 360s from what I have read. I had a 240mm aio from Thermaltake, was okay, RGB was okay but software was below par. Now I have the H115i platinum from Corsair. Its a 280mm rad so it has the 140mm ML fans and its really quiet, and does run cooler than the 240mm rad. Corsair has a pretty good RGB set up in my opinion, software gives me no issues really. I like how you can find online lighting profiles and just download them and load em up to your system. This is more crucial with full system Corsair stuff like mine, but can be useful regardless.
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
On 12/2/2019 at 10:11 PM, OlympicAssEater said:
Corsair H115i Pro RGB Platinum 280mm aio
Corsair H150I Pro RGB 360mm aio
Cooler Master MasterLiquid ML360R
DEEPCOOL Castle 360EX
Corsair Hydro Series H100i PRO RGB
Hey, yeah i have been looking at the deepcool one for a while but i thought deepcool was like a "overpriced budget" thing that no one liked
but are they good? even the 280mm ones?
MY RIG
