12 minutes ago, PetrZekrom said:
Hi you all im looking for a pc case that is an eATX factor compatible best would be when it would have a tempered glass side panel.
Thank you all for any advise love you all. U w U
011 dynamic XL, but what's the budget/country for the build and what do you need it for?
-Moved to Cases and Power Supplies-
^This^
