Optimal fan configuration for corsair h115i platinum
Solved by 00RaZoR11,
11 hours ago, Forzurda said:I'd prefer to have the fan RGB visible, but if I can get more performance by not having it so, then it's ok.
well blowing air towards the front panel, "out of the case" would not work at all. You'd see that in 10 minutes. The air would get recycled by the aio fans because it would have nowhere to go.
If you really want to see the RGB, install them in "pull" config.
Your best bet is installing the rad in the front of the case, the fans pulling air throught it, into the case. If gpu temps get too high, I'd try slowing down the aio fans or speeding up the exhaust fans.
