https://linustechtips.com/topic/1129249-starting-my-first-build-amd/
12 minutes ago, Gomez9800 said:
What do you need the PC for, what's your monitor resolution/refresh rate? Do you already own said monitor?
you don't need a key to install windows, you can install it for free, otherwise you can get a key for $5 on ebay that will work just fine.
Desktop benching:
5 minutes ago, Jurrunio said:
The only thing I was worried about the asus tuf gaming motherboard was that it doesn't allow for bios flashback and also is the 850w power supply too much?
I going to buy 144hz monitor pretty soon and thanks for the advice on the windows key
a few things to note,  x series motherboards are not needed unless you plan to run SLI.
do you really want to spend that much on a Cooler? a decent $25 cooler will do a lot,
your windows key is pretty expensive. just get one for a few bucks from ebay
850w is plenty
also your startup disk doesnt need to be 1tb,  if all your games and files are going on the HDD, no need to get 1tb.  most games are around 40-100 gb.  im not sure how big your library is, but i only play a few on the reg.
Ryzen 5 -5600x
ASUS x570
EVGA 3080 XC3
4x8gb 3600 mhz XPG
like 1080p 144hz? Because you can easily fit an ultrawide 100hz monitor into that budget
Just got the best value parts everywhere basically.
The RAM you had was only CL18
that 6TB drive just happens to be really cheap right now
You can get the monoprice Zero G for $299 right now as well
https://www.monoprice.com/product?p_id=38035&abtv2
Really shouldn't need to worry about BIOS flashing, the VRM should be better on the ASUS board
PCPartPicker Part List: https://pcpartpicker.com/list/DXLRvW
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($299.99 @ Amazon)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($179.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($69.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($82.99 @ Newegg)
Storage: Seagate IronWolf NAS 6 TB 3.5" 7200RPM Internal Hard Drive  ($129.99 @ Newegg)
Video Card: ASRock Radeon RX 5700 XT 8 GB CHALLENGER D OC Video Card  ($369.99 @ Newegg)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($85.98 @ Newegg)
Monitor: MSI Optix MAG341CQ 34.0" 3440x1440 100 Hz Monitor  ($379.99 @ Amazon)
Total: $1758.89
Generated by PCPartPicker 2019-11-29 23:01 EST-0500
850w is plenty
I will not be running SLI but since im running m.2 drive I want to use pcie 4.0 so that reasons for x570 motherboards and also I already bought the CPU since due the great deal that it its at and yea I was looking into buying a windows key. Regarding the 1tb boot drive I have a great wide steam library and would opt to put some of the games I play more often on the ssd not all but since games these days are getting bigger it doesn't hurt to get 1tb.
Total: $1758.89
The monitor is not something that is being considered on my pc budget that why im getting the 2070 super as I have on its own seperate budget 300 ish mark
no need for bios flashback since X570 supports 3rd gen CPUs natively
850w isn't too much, 750w will do for 3950X + 2080ti so it's good for plenty of upgrades
Desktop benching:
The 2070 super is only about 5-10% faster than the 5700 XT. Really start to lose performance per dollar going past the $400 mark.
Though with the other savings you could jump up to a 2080 super even.
