What CPU? Motherboard? Case? Overclocking?
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056746
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056750
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056770
Just now, Oakmeal said:
I really thought you were going to recommend me the NH-15 or is it ND-15 Either way its Noctua because i am bad at remembering things
Or that. I have a D15 and it's been super great. And ya got it the first way around haha
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056787
Why not stick with your current cooler? Are temps too high or cooler too noisy?
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056798
Well I hear overclocking with it wont be very good.
Have you tried using the cooler and / or oc'ing? If not, do so first. You can always decide to replace it later if you're not satisfied with the performance or noise.
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13056808
Deepcool Assassin 3 is also an option. it looks better than noctua too lol
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13057018
10 hours ago, Oakmeal said:
Noise isn't a problem for me (thank god)
That doesn't really answer the question. How high you can go currently? So do you know cooler is your limit and not the CPU itself.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13057912
12 hours ago, Oakmeal said:
But if i may ask how come you didn't recommend a AIO and why Dark rock pro? If i may ask im not saying it's a bad choice but Dark rock never really gets suggested for Air cooling as much im just curious if you don't mind answering.
Check your temps first with a overclock like others said, but people mention the Noctua because its proven name brand thats been around for years.  Known to be excellent in regards to both noise and thermals, and if not always at the top of the charts for cooling, very very close.  They arguably started the trend where people could view certain air-coolers as superior to most AIO watercoolers.  Also they finally come in Black for 10$ more instead of poop and more poop browns.
By your own logic, the Reeven Okeanos RC-1402 is another great cpu cooler people forget about (if you dont mind yellow fan blades), likewise some tests have shown the Dark Rock Pro 4 as superior to the Noctua (under load), but its new enough some people aren't aware of this, and or people still cling to Noctua's reputation.  In no situation are any of those 3 coolers "bad.", you are trading thermals at nearly the "margin of error" level, like 1-2C, as you are with Noise (atleast between the Noctua NH-D15 and Dock Rock Pro 4.)
You have options if you want to go with air cooling, pick whichever you like the look of and fits your budget between those 2 or 3
https://linustechtips.com/topic/1125042-cooling-cpu/#findComment-13058160
