Carbon Fire
Bitfeinix Prodigy Hackintosh Build.
I decided I wanted a small build that could be made to dual boot Windows 7 and Mavericks. I intend to use this in a College dorm room. I am a gamer but also a developer.
Parts:
  • Intel i7-4770k
  • Asus Maximus VI Impact ITX
  • Corsair Vengeance 2 x 8gb 1600mhz
  • Corsair H80-i with Corsair SP120 Quiet fans.
  • ASUS GTX 660 DirectCUII
  • Bitfenix Prodigy Black
  • Kingston HyperX 120gb SSD (OSX boot drive)
  • Samsung 840 120gb SSD (Windows 7 boot drive)
  • Seagate Barracuda 2TB (Expansion Storage)
  • Corsair CX 500w Semi-Modular
  • Bitfenix Spectre Pro 230mm
  • Bitfenix Alchemy Red LED
  • Silverstone Tek Sleeved Cable Extensions (6pin and 24pin)
  • Black Carbon Fiber Vinyl Wrap (Found here)
PC Part Picker - http://pcpartpicker.com/b/LqF
My Website with more pictures - http://geckoder.com/?p=25
The Build:
The Asus motherboard was surprisingly difficult to install into the case. It didnt want to fit. I managed though. The H80i barely fits. The water tubes are very badly twisted and I fear the flow is slightly cut off but the performance is still great. The cable management isn't bad for an itx. I was able to tuck a lot of cables behind the psu. It is never easy building in such as small space. Also the power in my house went out as I was installing the i7 which was scary since I needed to work with precision. Besides that works great now. Added this cool Carbon Fiber looking wrap to cover PSU and HDD. Stuff is super cool. Might put it on the Radiator of the H80i.
Todo:
  • Add sweet logo to side panel using red carbon fiber vinyl.
  • Better lighting.
  • Upgrade GPU
  • Mod front panel to be more red themed.
Mostly Completed Build Photos:
post-31674-0-66856700-1391713500_thumb.j
post-31674-0-08746000-1391713510_thumb.j
post-31674-0-90748800-1391713511_thumb.j
post-31674-0-00132400-1391713502_thumb.j
post-31674-0-00412000-1391713504_thumb.j
post-31674-0-11026400-1391713506_thumb.j
I will add more photos once the red carbon fiber material arrives.
Carbon Fire ITX PCCPU: i7-4770K@3.8Ghz GPU: Asus GTX 660 Cpu Cooler Corsair H80i Mobo: Asus Maximnus VI Impact RAM: Corsair 16gb 1600MHz PSU: Corsair CX500 Modular SSD: 2x120gb HDD: Seagate 2TB Keyboard:Corsair K70 Mouse: Logitech G700  Case Modded Bitfenix Prodigy
https://linustechtips.com/topic/112040-carbon-fire-prodigy-build/
Quite a nice looking build but i have 2 questions. 1. Why a 660ti? 2. Why is that case so dusty?
It is a 600. I chose it for an old build with a smaller budget. Want to upgrade to a 770. I should have used more compressed air to remove the dust. Maybe I will take some new photos.
The letters on the side look awful. Why not get some printed/cut with a vinyl printer?
I know. I was just testing out the material while waiting for the red to arrive. I plan on redoing with a combination or red and black. I cut it by hand because I am a cheapskate.
Looks great so far :).
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
  • 2 weeks later...
Here are some updated photos of the designs I am adding to the case.
Logos: Hackintosh, Bitfenix, Asus ROG, Nvidia, Corsair.
post-31674-0-68664000-1392520699_thumb.j
On case with new text.
post-31674-0-83972800-1392520717_thumb.j
More photos to come.
Here is the case with more red carbon fiber added. I the corners on the front are a little rough, I am planning on fixing them. Enjoy.
post-31674-0-84876300-1392602492_thumb.j
post-31674-0-10066100-1392602542_thumb.j
post-31674-0-33625100-1392602609_thumb.j
post-31674-0-70495300-1392602701_thumb.j
post-31674-0-34165700-1392602728_thumb.j
post-31674-0-68685200-1392602895_thumb.j
post-31674-0-63016300-1392603005_thumb.j
  • 3 weeks later...
A little out of order, but here is a render of the computer I made in SketchUp.
More images to come of other side panel with possible design on it. Also still working on adding to the SketchUp Model.
digging the carbon fiber, no so sure about the black and red mix though...
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
Looks like a badass dragon.
Thanks I put a red Phoenix on the other side panel. Not quite a dragon.
I really like working with the carbon fiber material. The red and black was based off of my Motherboard and GPU thought I would stick with the theme.
Damn dude when you put that red on it.. I lost my **** ..I love it.
// Gigabyte 990FXA-UD3 // AMD FX-8320 CPU @ 4.3 Ghz (7-21.5 Multiplier) 200.90mhz FSB CPU-Z Validated // Kraken X40 AIO - 2x140mm Push-Pull // 4GB Corsair Vengeance LP - 8GB Avexir Core Series Red 1760Mhz // Sapphire R9 Fury Nitro 1130mhz/4GB 1025mhz (Effective) GPU-Z Validation // Corsair SP2500 2.1 & Microlab Solo 9C Speakers // Corsair K90 Silver - Cherry MX Red & Blue LEDs // EVGA SuperNova 850w G2
Thanks man.
You did a stellar job with your rig. I love the red/black combo.
Thank you. I like the combo too.
Very nice internally, but for the Carbon Fire Logo on the outside try getting a laser cut piece of metal there, using the scissors etc doesnt make for an even finish.
You are probably right. I tried to make that piece a couple of times with but that was the best I got. I like in the middle of no where so getting it laser cut might be hard.
Is there any particular reason you didn't go with a windowed sidepanel?
Anyway loving this build! Good job!
I didn't use a window because I feel it is way overpriced and I fear it will hurt the airflow. I prefer to just take the whole sidepanel off if I want to show off the internals. I might try to mod the panel for a large window and if I mess up buy the windowed one.
red accents look sweet man good job
Thanks still working on the front might add some stripes or something.
  • 2 weeks later...
@Paulandpedro did you need any tools to handle the carbon fiber? like heating it up or anything like that.
I just used an xacto knife, but for the front panel a heat gun would have helped and made it easier but wasn't required.
  • 1 month later...
I ended up buying a heat gun to finish the front panel. Heat gun helps a ton when working with the material.
  • 11 months later...
More info about the build can be found: http://geckoder.com/?p=25
Mostly just a recap of what is here, but if people wanted to see a little more about this.
