looks similar-ish in performance to a arctic freezer 34. perhaps a bit lower.
seems fine in terms og mounting.
id recommend looking at the arctic freezer 34 esports one/duo over it tho.
13 minutes ago, Mr. Question Asker said:
So I am going to buy Cooler Master Hyper 410R cooler, so how is it?
Your opinion matters a lot to me and how is the installation process, is it easy or hard?
(Please write down your thoughts) :)
If you have money to spend pay 85 bucks and get the DRP4. but if your not going to do hardcore overclocking then the hyper 410r will suffice.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://www.teckknow.com/cooler-master-hyper-h410r-cooler-review/3/ - Looks alright for the price 25 usd - I you are going for something better I would also recommend something better like the 212X/212 black edition -> Dark Rock 4 -> Dark Rock Pro 4
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
I agree with this. Should perform better for the price.
Do I need to remove the Mobo to install the cooler, and is it fine to remove Motherboard to install a cooler?
My CPU is Intel i5 8400, would consider Hyper 212 or Black edition of it, as others and you gave me nice suggestions!
You would be good with the hyper 212 black edition.  Since it is not a K chip it will be cooled very well.
Its likely you can manage to install it without removing the board. Can be a bit tricky tho.
Hyper 212 is a nightmare to install. Hyper 212 black edition is not.
Would take the arctic freezer 34 esports one over both.
I agree it would be tricky without removing the motherboard, but if I remove and properly install the cooler then will any damage cause to my mobo If I remove it and install?
Only damage can be if you tighten the screws so tight you chip the motherboard.  That is not going to happen tho just screw it until its tight.
No, you will be fine.
To quote from some random person
Quote
Screw with confidence, not force
-someone, 20xx
What case are you using? Most modern cases come with a motherboard tray cutout for access to the back of the board without removing it for cooler installation.
The H410R would be fine for cooling the 8400 but there are probably quieter alternatives available if that's what you're aiming for.
What case and ram are you using?
Where are you shopping / located? Budget?
I am using Cooler Master Elite 311!
I am using Corsair Vengence RAMs (2x 8GB =16GB @2400MHz), I am shopping from Amazon.in and I am from India!
Sorry for the late reply -- been a bit busy.
Yep, that case includes a cutout in the motherboard tray for installing coolers.
I'm not seeing anything strictly better for the price than the H410R and it's plenty for cooling so it's a good option.
Yes, my package is coming tomorrow and gonna install and clean my PC along with the installation, tired of the shit cooler noise (Intel Cooler) :)
Update on my Cooler Installation!
I have installed Hyper 410R, because of budget problems, it works great.
TEMPS -
Stressed the CPU for 5 Mins
Stock Cooler = 75C Celsius
Hyper H410R = 57C Celsius
18 Degree temp improvement and noise is gone that was coming from the Stock Cooler!
