DSLR for beginners recommendation
Go to solution Solved by ThePointblank,
The bulk of the stuff that's in that kit is stuff that is either useless or crap. As you get more serious about photography, you'll be replacing practically the bulk of the stuff that they've thrown in there with higher quality items.
And I would be very careful about buying refurbished Nikon gear off Amazon; for one, the camera or lenses could have been a grey market import, and Nikon is exceptionally strict about grey market reselling; Nikon will automatically deny service to a grey market import item, even if you are covering the cost. And yes, Nikon can tell if an item is a grey market import.
I would recommend this Canon refurbished Rebel T6i with the 18-55mm lens instead:
https://shop.usa.canon.com/shop/en/catalog/eos-rebel-t6i-ef-s-18-55mm-f-35-56-is-stm-kit-refurbished
It's an much better camera with more features, such as WiFi, and a flip out touch screen.
Hi guys.
Looking for a DSLR camera kit. My budget is about 400/450 usd. I'm a beginner and I want the camera for learning purposes. I would like to have lenses that are good for most shooting situations. I was looking at this Amazon listing but you guys should know what's best.
T3i/4i/5i, plus a 50mm prime lens. You can also get the Panasonic G7 for that.
The one you linked is another option, though honestly you don't need the 70-300.
If you're not in a hurry, wait for Black Friday.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
12 hours ago, joser1813 said:
Hi guys.
That will do fine, has everything you need to get started.
The lenses are fine also, gives you the full range from 18mm to 300mm.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Save and get a used D3400
The D3500 doesn't change much. Unless video is of any importance, D3400 serves you just fine
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
True, but for $420 for everything that kit provides, that's a great value given everything it includes.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
