USB 3.0 Hub (I need some explanation)
Go to solution Solved by TheKDub,
If you plug a hub into a USB 3.0 port (640MB/s), the connected devices have a maximum of 640MB/s available.
So if you had an SSD connected to it and were copying files from it around 400MB/s, the rest of the devices only have about 240MB/s to use until the SSD is done.
You can connect USB 2.0 devices to USB 3.0 ports, and USB 3.0 devices to USB 2.0 ports. (However I wouldn't recommend it unless speeds aren't a concern, as USB 2.0 is quite a bit slower)
Okay,
My board doesn't have enough USB 3.0 ports.
So I'm planning to add PCI adding card to get more.
But not sure if that's a good idea.
What if I added USB C USB hub?
Does the bandwidth gets split? Or if I plug it into USB C at the back all the USB 3.0 ports on it will work full speed of 3.0?
I'm asking because I need to plug in some devices that specifically require USB 3.0 speeds.
I know it could be a dumb question.
If the bandwidth is not split, and they all work full speed it will save me from wasting £100.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V (real voltage 1.305V + - Temps 77-80 P-Cores, 66-68 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
HTPC: 13900KS SP111 5.9Ghz P-Core 4.8Ghz E-Core 1.43V LLC7 (Real Voltage 1.4V) with Supercool Direct Die, RTX 3090 ASUS Strix White with Active Water Block, ASUS Strix Z790-F Motherboard, 2x16GB DDR5 8000Mhz running 7600Mhz CL38, 4x 2TB Samsung 990 Pro NVMes, 3x 360mm EKWB PE White rads 3x 480mm external XE EKWB rads with 2x D5 pumps (single loop) with 21 Uni fans, G5 Odyssey 144Hz 1440p monitor, Keychron K3 slim mechanical keyboard and Basilisk Ultimate mouse, Corsair Elite Wireless headset.
https://linustechtips.com/topic/1118646-usb-30-hub-i-need-some-explanation/
9 minutes ago, TheNaitsyrk said:
Okay,
You can get away with a non powered hub by getting one that has a USB to extend. and plug that into a usb 3.0 port on your motherboard.  I guarantee you this will work proper.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
First of all, what motherboard do you have?
Do you have USB 3.0 and USB 2.0 headers on the motherboard? Most motherboards have extra headers.
If so, you could buy USB 2.0 or USB 3.0 brackets and attach those brackets in the back of your PC and move your low bandwidth devices to those USB 2.0 ports (keyboard, mouse, maybe usb speakers etc)
What device are you trying to connect to usb 3 ports?
A USB Type C hub is still a USB hub, Type C connectors are not something magical, they're just designed to allow you to insert the cable whichever way you like.
If a USB hub is plugged in a USB 3.0 port, the hub will get 5 gbps.  The devices plugged in the USB hub get bandwidth out of that amount, as they need.
The amount of bandwidth each device will use will depend on the device, what data packets they send through the USB cable and other factors.
You can expect approx. 4.5 gbps of bandwidth from a USB hub, merging the data from multiple usb ports is not free.
If you buy a USB 3 controller, the maximum speed you're gonna get will depend on the slot you're gonna plug the card in.
USB 3.1 gen 1 ( 5gbps) has in theory a peak of around 550-600 MB/s.
A typical USB 3.0 / USB 3.1 gen 1 card with two USB ports will be connected to a pci-e x1 slot, so you'll have either 500 MB/s or ~970 MB/s of maximum bandwidth (pci-e 2.0 vs pci-e 3.0). That's the maximum theoretical speed of pci-e x1, in reality due to overhead and arranging data in packets and all that, expect at most something like 480 MB/s or 950 MB/s respectively.
If you need throughput for a usb capture card for example that sends raw footage over usb, best to keep it on the usb ports created by the chipset, so that it will go direct usb -> chipset -> sata / nvme and move other stuff to a separate usb controller card.
2 minutes ago, mariushm said:
I need it for VR, and all other USB devices.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
