Changing motherboard (What should I do?)
Solved by Enderman,
1) put any files and documents you want to keep on the HDD
2) unplug HDD
3) install windows and your programs on the new SSD https://www.howtogeek.com/224342/how-to-clean-install-windows-10/
4) with the computer off plug the HDD back in
5) go into BIOS and make sure the SSD is the first boot priority
6) boot into windows and everything on your HDD will be there, you can move files back to the new SSD if you want
7) you will need to tell steam and other game launchers where the games are on the HDD
