Help Choosing CPU
Solved by veikko315,
Ryzen Circlejerk aside,
Get a 9600k with a full sized Noctua and a board of your choice. Grab a nice 16gb kit. Ask around which Intel boards are the best for O/Cing. Toss this setup in a cheap case with a decent PSU and be done with it. There isn't much the 9600k won't drive at 5ghz. It's a great value, and unless you're trying to open 10 other applications while you game and stream there is little advantage to going with Ryzen. Intel is tried, tested and true. Go on Userbenchmark youtube Videos and check out the Ryzen vs Intel benchmarks. Look at the 0.1% lows on Ryzen. Ryzen is not a stable CPU at all in games, the FPS fluctuates like crazy. Not my idea of a party.
