I am sure this topic has been beat to death, I've been noticing my cpu is still idling rather high even after flashing F5b bios. I have a custom loop water cooled rig, which manages to keep my asus strix 2080ti to 50c under full RTX load. Yet it cannot seem to keep my 3700x under even constant temps at idle, usually see somewhere between 33c and 55c at idle, and actually had a thermal shutdown the other day while playing a semi older game (dying light). I'm a bit curious why I'm STILL having so many issues with temps on this thing. Are there settings in bios I need to change or are we still going with AMDs explanation of "Thats what it's supposed to do"
https://linustechtips.com/topic/1114624-r7-3700x-temps/
Do you know your water temperature at idle?
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974591
Do you run with auto overclock aka PBO? What is your thermal`/current limit set to. Maybe it's too high. CPU boosting way out of temp limit and crashing?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974592
2 minutes ago, OdivValknir said:
Since you have soft tubing, the quickest way to convince us you have adequate mounting is to take off your CPU block and send a picture of the thermal paste spread on both the IHS and the waterblock
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974649
I guess I may have to do that. I wont have time till this weekend though. I really hate to go messing with the damn loop.
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974716
As a general comment, 39 degrees is fairly warm for idle fluid temperature, even considering it looks like an SE radiator from EK?
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974728
It's actually a PE, so it shouldn't be that warm. The case is a TT view 71 So the air flow in the case isn't terrible. I could probably use push/pull on the rad, just didn't have the money for 3 more fans by the time I finished the build.
I actually just took a look at icue, and its showing temp to be 28.5 at idle currently. So maybe I was off when I said idle water temp earlier.
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974738
Maybe until you have this sorted you could run the fan/radiator outside the case just to rule out some airflow issue.
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974745
55 minutes ago, OdivValknir said:
Water temp at idle is around 39c
That's pretty high. Seeing CPU temps 16°C higher than the water for a second or two should really be expected with a water temp like yours.
NAS & Proxmox:
ML-Compute Server:
Phone: Oneplus Nord
Peripherals:
Cameras:
Mountainbike:
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974747
Do you monitor the CPU temp with HWinfo or Ryzen Master?
In HWinfo, the core temp is the hottest core. So when, say Windows doing update in the back ground,  a few cores will spike to 55C. But the rest of the cores are 30C because it's idling. When you use Ryzen Master. The temp is all cores average. Then the idle temp is very stable. My 3900X with a 280 rad stays at 32-34C when idling.
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974750
I checked that earlier, and hwinfo and ryzen master are reporting same temps.
https://linustechtips.com/topic/1114624-r7-3700x-temps/#findComment-12974755
