I keep breaking my headphones
1 hour ago, Alpha17x said:I'd like to get better and potentially more expensive ones but I've long been afraid to because I don't know what I'm doing that's causing my headphones to break. and like I said, I have actually gone into consultation about it because I'd just like to get some and have them and for that to be that. I strongly feel that while sound quality has definitely gone up, actually construction has suffered over time. I have a pair of not great sounding cans from the early 90s. I could spike those into the ground and they'd still be fine... I say this because as an angry child I spiked them into the ground.
Or you could just be buying headphones with awful construction. Beyerdynamics are usually built like tanks look at the dt990,dt770,custom one pro , and custom studio those are all mean to be abused if you break something you can go to the beyerdynamic website and just buy the part to replace it. Still wouldn't reccomend Sennheiser to you as you might be the type to slam stuff on the ground. Takstar pro 82 is super well built for a Chinese can, the m40x has great plastic build quality even better than the more expensive worse sounding m50x.fostex has always built tanks. You are honestly probably just looking at the wrong places
