Yes, 4c/4t in a CPU bound game... sounds about right.
"Black Out"
Dedicated Streaming Rig
24 minutes ago, budgetguy said:
This isn't normal is it? what could cause it?
Not normal, but common. I achieve 105-125 fps using an older 6th gen i5 clocked at 3.0 GHz in 1440p using these settings...
You can try 96, 97, 98, 99 or 100 resolution scale since your CPU is better than mine. I set it to 95-99 to take some strain off my CPU. Going any lower makes visuals too blurry, 95-99 are spots that are barely noticeable. Hope this helps.
Oh and trust me on the textures at Medium. BF1 is one of the very few games that you can barely notice the difference visually. If you prefer to keep it at Ultra, that's quite alright as it doesn't affect fps that much. I do it because like I said, the visual difference is almost impossible to notice.
will try these settings tnx a lot
Mesh Quality, High???? LOL why with this hardware
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
28 minutes ago, budgetguy said:
afther trying a lot of different settings nothing seems to work. i get the same amout of fps on ultra as on low, i might try to reinstall
If there's no change in fps from ultra to low, it's something with your PC causing it. In which you would have to track down on your own.
