Dark rock tf leaking oil?
AFB_MD
Hi. I purchased a brand new Dark Rock TF on Amazon a few weeks ago but only got to test it this past weekend.
After the first day of usage, i noticed a small amount of some sort of liquid (see picture below) on the inner side of the casing of the top fan, that turned out to be some sort of oil for which I don't know where it's coming from.
I contacted be quiet's tech support and they mentioned it's totally abnormal and i should to ask for a replacement. However, they didn't provide any possible expalanations as to where was the fluid coming from.
After reaching out Amazon's support they issued a refund in the end and allowed me to keep the defective cooler, as it was more expensive for them to cover shipping expenses for both the broken part (from colombia back to their offices in the us) and sending me a replacement. Of course, that means the apparently defective cooler would be out of warranty after the refund is made effective.
So here i am now, in a weird spot:
1. In my opinion, the cooler is working just fine: So far, my CPU temps (ryzen 5 3600) have been between normal ranges both iddle (average of 40°C on at 20-25% fan speed) and while gaming (reaching 75-79°C at around 80-90% fan speed, with battlefield 5, which happens to be the most demanding game on my library) - For context: PC case is a phanteks p400s eith tempered glass pannel and the top sound dampening pannels on, and with 2 of the stock phanteks fans on the front and 1 cheap thermaltake fan for exhaust, on the back, plus a vertically mounted gtx 1080. I did OC the CPU with ryzen master, but only by activating auto overclocking in the game mode profile (i'm totally new to CPU overclocking and just followed the basic steps listed on a guide i found here, somewhere)
2. However, I fear that this would become an actual serious problem in the future, with the worst case scenario being a massive leak of some kind of fluid, inside my system.
With the money from refund, I could just buy a new cooler, but It actually will cost me about 30 dollars more now than what i paid before, accounting for price changes and fluctuations in the US dollar exchange rates. And, although for you 30 USD might not sound as much, after making the conversion to my local currency, it's not a small quantity for me (to keep it in perspective, it would be about 10% of my monthly savings). So i was thinking of just keeping the "damaged" cooler installed and see if the problem persists, after a few days. If so, i would get a new cooler. But if i don't notice any leaks, i could use the refund money to get some new parts for the system i am currently trying to build ( i still need power supply, a new case and a couple of SSDs).
The thing is, i really don't know from where that fluid could be leaking out. Initially, i thought it could be a small leak from the fluid dynamic bearings of the fan, but what if it's coming from the heat pipes. I don't know what kind of fluid is used in either of those cases (the fan bearings and the heat pipes), and this is an oily fluid, as i mentioned above.
If it's coming from the fan, i think it's possible to get a spare fan to replace it. But if its the heat pipes, I wouldn't take any chances and get a new cooler.
The fans don't make any weird noises and they spin normally and ramp up or down perfectly fine, according to my specified fan curves. Temps are ok. The cooler is louder than I expected (based on youtube and some online reviews), but only when close to the top speed and the noise isn't bad. Its actually less than the noise made by the case fans. I have never tested any other be quiet fans before, so I couldn't tell if the noise levels are normal or not.
I like octopuses
it's probably just a damaged fan so you could just buy a fan and not the heatsink, to save money
as for what the liquid is, I assume bearing lube. There's no way oil from thermal pads can reach up there.
Desktop benching:
As mentioned, it's probably lubricant and isn't dangerous or much of an actual problem unless the fan starts to slow down.
Have you tried contacting BeQuiet! for the replacement instead?
It was the first thing I did and they told me to ask for a replacement through the retailer (amazon in this case) or send an email to their head quarters. In the end, i went for the refund with Amazon.
Afterwards, I sent another email to Be Quiet to see if it's possible to get an spare fan alone. I'm still waiting for an answer.
I like octopuses
Good news is that there won't be any massive leaks. O-ring sealing motor was probably loose, letting lubricant out. There's just drop of it, and they don't use conductive oils with electronics. So messy motherboard is worst it can get.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Probably the fan bearing. Check the heat pipes for puncture.
may have been damaged during shipping.
I really hope that's the case. Anyway, a spare fan is on the way from germany (took a while to get an answer from be quiet's main offices lol). I read in another forum that heatpipes don't use oily fluids to work so, all in all, it does make sense to be the case of a leaky fan. never thought that could happen. Anyway... i guess i ended up with a free premium air cooler in the end? lol (too bad it's warranty was invalidated though)
I like octopuses
