Case recommendation
Go to solution Solved by WoodenMarker,
Can you link to any other shops? Selection seems to be pretty limited.
If you're limited to this shop, I'd recommend a P350X. You can reuse your current case fan for rear exhaust.
http://extremetechcr.com/tienda/componentes/2393-phanteks-eclipse-p350x-negro.html
Hello guys!
I would like to get a case recommendation. There are far too many options in the market and I'm not sure where the sweet spot is. I have a budget of around 80ish USD (in my local currency it would be ~ 50000 CRC). I'm looking for a mid sized case with a good room for cable management, good airflow and decent looks. I will be shopping at my local store, not Amazon. I would like to know which one of the listed cases would you guys choose. I'm currently stuck with a Thermaltake V3 Black Edition which is pretty subpart.
Page is in Spanish but you can clearly see the model and price:
http://extremetechcr.com/tienda/25-cases#/tamano-mid_tower
Eventhough I could go as much as 80 USD, I'm looking for expending just as much as necesary
https://linustechtips.com/topic/1111938-case-recommendation/
What's subpar about your current case? What features are you looking for?
System specs?
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12953493
System specs?
It has very little space for cable management. No USB 3 at the front. Looks dated. Airflow is meh. You could say the case is ok in general but sometimes it's very diffcult to work with it so I want an upgrade.
I mostly care about price/performance. I'd like enough room to hide the cables, good arflow, nice materials... basically a good all rounder. Looks are not top priority but it would be nice if it doesn't look ugly.
My system is very modest at the moment but I might upgrade to a Ryzen build in the future:
i5 4460 (stock cooler)
Asus board micro ATX
16 GB DDR3
RX 570 4GB
2 TB HDD
160 GB SSD
500W System Power U9 PSU
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12953621
NZXT have recently replaced their H500/H500i with the new H510 case.
Most stores in my country were selling the older cases with some good discounts so that may be an idea.
But tbh you arn't gonna find any great cases under 80usd.
The Corsair Carbide 270R looks alright though
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12953667
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12953744
http://extremetechcr.com/tienda/componentes/1332-azza-inferno-310.html
http://extremetechcr.com/tienda/componentes/3027-cooler-master-masterbox-mb511-rgb.html (<-Top recommendation)
The above suggested P350x is also a very good case.
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12954281
I tend to prefer the mentioned store because they have better prices most of the time. Here is the other local store: https://www.intelec.co.cr/pcgaming/case
I have another 120mm that I added to my actual case so I could add 2 to the new one
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12954791
Yeah, I don't see anything better on that site.
An extra fan helps though.
https://linustechtips.com/topic/1111938-case-recommendation/#findComment-12954988
