Posted October 3, 2019 Hello can you please help me recommend a computer, as there is so much to choose from. I need a new laptop for college work (mostly word documents, powerpoints and Maple use) Will also be using the laptop for normal webbrowsing and youtube. MUST HAVES: i5 and 8 GB ram NICE TO HAVE: Good portability and a good screen. I went to a electronics store to try some different keyboards and mostly liked the ones from Lenovo Budget is around 1000 USD but preferably cheaper. OPEN TO ALL OPTIONS, please recommend. TIA Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 4, 2019 Lenovo Ideapad 340S has i5 8th gen with 8 gigs of ram and 256GB SSD. is around 700$ Spec: Macbook Air 2017 ProcessorPU: ii5 (I5-5350U | | RAM: 8GB LPDDR3 | | Storage: 128GB SSD | | GPU: Intel HD 6000 | | Audio: JBL 450BT Wireless Headset | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
