So,
I was searching the right Pc case for my build for about 3 years, no case had the right layout, Style or Size!
But about 3 Months ago I found the lovely P50, let's start:
The Case is made out of Aluminium and features a Tempered Glass Window,
it is so light that I thought it was made out of Plastic while unboxing it, but it is very strong and the build quality
(As far as I know its made by Jonsbo) is Great.
The Build:
The case is obviously for ITX only and on their site you can buy a Flex-ATX psu (only supported psu), but i went with a Corsair SF600 Platinum, wich should fit, according to my measurements!
I5-8600K
16GB Corsair 3000Mhz
Samsung 970 EVO 512GB
Asus z370I itx + EK Monoblock
Zotac GTX 1080ti + Bykski Full Block
EK SPC-60 Pump
Phobya 560mm Radiator + EK VARDAR 140mm (x4)
-Flexible tubing/ Fittings from EK
The Plan:
At the moment its kinda not done, and the glorious Kaiser is chilling on top of the pump, my plan would be either Cyberpunk 2077 or Battlefield 1 Themed, wich is very different from each other...
Gott erhalte Franz den Kaiser und greeting from Austria!
https://linustechtips.com/topic/1109730-zcase-p50-review-n-build/
-Moved to Member Reviews-
