Best Bass Headphones under $500 (not Skullcandy scam)
Solved by rice guru,
16 minutes ago, berny22 said:ok.. can i get the 770 M instead of 770 Pro, I want the leather pads
I wouldn't get the 770M apparently you loose bass as well as soundstage I would stick with the pros and just replacement pads that come with the custom one pros. actually completey forgot the custom one pros existed they are better built beyerdynamic closed back to me sounds worse not bad just not as good as the 770 but has the bass feature where you can turn it up to literal robot sex on a tympani. it does have a detachable cable and shitps with leather pads that should be compatible with the the 770
