Using a be quiet dark base 900 pro rev 2 case with Asus Rog Strix X570-E motherboard.
The case has a cable from the PCB Panel Box at the back of the case (runs LCD, fans etc) and has a cable coming off it which has, what looks like,  a 4 pin "fan connector". The manual states " PWM connector to the motherboard". I am confused as to where on the motherboard this one goes. I have a CHA_Fan1, CHA_Fan2 and an extra CPU Fan connector. Does it connect to one of these please?
There is also a spare motherboard AIO pump connector which I am not using.
https://linustechtips.com/topic/1108063-case-cable-connections-problem/
Any CHA_Fan connector will do. But make sure that it doesn't pull more than 1A from the motherboard because it can damage it.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
As a newbie you have lost me! How can I ensure that this is not the case. All be Quitet (just responded to my email) is "The PWM Cable can go to any FAN Header on your motherboard. Just make sure you set it to PWM in your BIOS."
Fan headers on your motherboard can provide maximum of 1 amp each. So if you connect too many fans to it, it may damage the board.
I have the Rog Strix Z390- E and it only has two PWM fan connectors the rest are not, you need to make sure any PWM connection is connected to a PWM compatible header. Consult your motherboard manual or support webpage to figure out which headers are PWM compatible.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
This fan header that you've located is most likely for the Fan controller on the back of the case.
index.php?ct=articles&action=file&id=41941
Feel free to plug that into any CHA_Fan header on your motherboard, and then plug all your fans into this fan controller. NOTE: The Fan controller has a SATA power cable coming off of it which supplies the power to the fans, so make sure you plug this in! As @PopsicleHustler pointed out, Motherboard headers can only supply power to a few fans, so this is how many fans can be controlled with only one motherboard header.
