Best overall wireless headphones?
kiosion
I've been looking for a good pair of wireless headphones (not necessarily 'gaming' headphones) to use with my PC setup.
I figured I'd ask here, since y'all probably know more about audio than I do... Here's two headphones I've found so far:
- Audeze Mobius
https://www.amazon.ca/dp/B07JMNGSPB/
- Arctis Pro Wireless
https://www.amazon.ca/dp/B07HSC3WWL
Drop any suggestions you have, I'd really appreciate it!
My Folding Stats | Folding for COVID-19 research
System Specs
CPU • Intel Core i7 8700k @5GHz
GPU • GTX 1060 6GB
Motherboard • Asus Strix Z270-i
Memory • 16GB HyperX Fury Black
Cooler • NZXT Kraken X52 AIO
Case • NZXT H210i
Monitors • 2 Alienware AW2518H's
14 minutes ago, rice guru said:
I would say the mobius or the GSP 670
I'll look into the 670's!
System Specs
GPU • GTX 1060 6GB
Case • NZXT H210i
18 minutes ago, kiosion said:
I have the HyperX Cloud Flight gaming headset (not recommended get the arctis instead)
but recently got the Sony WH-1000XM3 NC headphones and they are really really really good all around.
i7-8700k @ 4.8Ghz | EVGA CLC 280mm | Aorus Z370 Gaming 5 | 16GB G-Skill DDR4-3000 C15 | EVGA RTX 2080 | Corsair RM650x | NZXT S340 Elite | Zowie XL2730
- Audeze Mobius
I use Sennheiser 4.50 BTNC sounds great.  Not over done in any area and just the right ammount where its a flat sound and clean sound instead of lots of noise and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
I love my current pair of Sennheiser's, I'll look into the 4.50 BTNC's for sure!
System Specs
GPU • GTX 1060 6GB
Case • NZXT H210i
Avoid the 4.50s like the plague. Closed Sennheiser = crap. Mobius is cool but it is plagued by a constant amp hissing that is annoying to me. Personally I would do the WH1000XM3 from Sony. Mobius is better sounding overall, but XM3s are an easy listen and a ton of cool features.
Except it is not flat but ok....
Sennheiser HD 4.50 BTNC Frequency Response
Own the 4.40 which is the exact same but no anc. It very no flat as well as just being ok for the price does the job well. But the detail is also pretty lacking.
Welp my current solution for wireless is just using my airpods, which honestly are not good for anything besides on-the-go music. So any pair of proper wireless headphones will be a good upgrade
System Specs
GPU • GTX 1060 6GB
Case • NZXT H210i
