Came across this bad boy when designing a thermal interface for high power LED's.
It would be awesome if LTT team could check this out as a replacement for liquid metal or any other cooling paste.
Conductonaut is only 73 W/mk by this site
I would love to try it, yet my 2600x and 120m AIO is not the best setup to see a great cooling difference.
BIG TDP cpu + air cooler would be how I would test it as it takes the variable of water cooling out of the equation, yet probably smart to test both.
+ as this pad is 25 microns thick, the cpu and cooler surfaces have to be perfectly lapped.
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/#findComment-12913378
6 minutes ago, carlhook said:
These only have high conductivity in the a-b plane. In the relevant c plane it has only 15 W/mk
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/#findComment-12913387
Just now, carlhook said:
All I can find in the datasheet is A-B plane as C axis.
A being the cpu side and B being the cooler side for instance.
C being the perpendicular axis of those planes?
a-b plane is basically the thermal conductivity down the plane of the sheet. (i.e. if you held the sheet one the edge, and heated the other edge). The C plane is the conditvity through the sheet itself (i.e. from one side of the sheet to the other side of the sheet).
So C axis is the thermal conductivity you care about. A-B plane is for the "spreading" ability of the sheet, but since there is an IHS, it doesn't really help.
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/#findComment-12913508
Ok, understood it now. Thanks bud!
That explains the "new special" material that is the IC Graphine sheet then.
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/#findComment-12913518
1 minute ago, carlhook said:
Yes, graphene sheets are underwhelming in performance since the sheet covers the whole IHS, bringing everything (at best) to the 15 W/mk thermal conductivity but at the same time eliminating any metal-to-metal contact  (which is better than 15 W/mk) that you would have had with conventional thermal paste (as it squeezes out, allowing for metal-to-metal contact).
There's another layer of this which is the presence of the IHS, making the graphene sheet further redundant, but please see below my more detailed reasoning.
https://linustechtips.com/topic/1107080-1600wmk-cooling-pad/#findComment-12913528
