XFX Radeon RX 5700 XT THICC II
The Thicc II has probably the worst design when it comes to the power delivery (VRM-s including power phases, capacitors, layout), a lot worse than the reference card but not so bad that it would prevent the card from being recommended (let's just say it does its job). It's probably the cheapest non-refference to make but it holds a price.
The PowerColor Red Devil, on the other hand, uses a doubled 5-phase VRM with good enough components (almost a 10-phase) which makes it the second best RX 5700XT choice on the market - right after the Asus ROG Strix.
MSI Evoke, Sapphire Pulse and Gigabyte Gaming OC are rather similar to the Thicc II but with some small diferences in design like usoing better mosfets or capacitors.
But the Evoke is bugged, bad thermal pad sizes and palcements make it hot and loud.
No true info on Sapphire Nitro+ and MSI Gaming X yet.
